Hello,
I wasn't sure how to categorise this question so feel free to move it into more suitable sub-forum.
I'm looking for some advice.
I'd like to route some (7-8) CAT6 Ethernet cables from downstairs living room (router) to the upstairs bedrooms. Most of the cables will be used for HDMI-over-CAT6 rather than data.
The walls are solid and old (1930s) so I don't want to do it the right way by chasing all cabling into the walls. However, I have the advantage of flooring being up due to it being replaced so I have full access to the underlying floorboards.
I see 2 options:
1. Go through the ceiling and place all cabling in trunking against the downstairs room wall. I'm not a fan of trunking but it'd be behind furniture and out of the way. Missus' approved. This would involve feeding cables through joists across the upstairs floor. I'm not sure I want to weaken 80 year old joists by drilling holes in them though.
2. Feed the cables through insulated cavity wall and run them in conduit along the external wall. I know all about drip loop, downward facing hole, etc. I had a new damp proof course installed 6 months ago on the wall I'd be drilling through. Would this cause any problems?
Thank you for your help.
Regards,
Kam
I see 2 options:
Regards,
Kam
