I have replaced a functioning "keyed both sides" Euro cylinder with a "thumb turn" version (to enable easier escape in case of emergency). The lock is fitted in a uPVC door with multi point bolt fastening. The lock has worked OK for a couple of weeks, but now refuses to work properly.
The cylinder mechanism still rotates OK, and engages the bolt if fully turned, but has to be rotated back around 20 degrees to extract the key. At this point, the bolt becomes been disengaged. The mechanism operates fine if the cylinder is rotated using the thumb turn (from inside).
I have put back the original cylinder -the door locks fine with key from either side.
I have compared the two cylinders and note that there is a difference in alignment between the cams on the two cylinders. Looking from outside, the cam on the original cylinder is aligned at about "8 o'clock" with the key removed. However, the cam on the new cylinder is aligned at around "11 o'clock". i am not a locksmith, but suspect this may be causing the problem.
Any ideas?
Any ideas?
