Hi, I am a newbie here, I have signed up in the hope someone can solve my problem. This boiler has always been erratic for hot water (c/heating fine) usually down to lower pump flow on hot water, if c/heating is on the flow switch just drops enough to to cut the burner, if the c/heat is off the pin dosent rise enough to operate the microswitch, so no burner.
Now after having appeared to cure this by replacing the diverter valve (sticking?) and removing and flushing the hot water heat exchanger and cleaning gunge from boiler pipework, I now have a different problem.
With c/heat off, if a bath is run, when the hot tap is turned off the boiler shuts down normally but then the temp rises off the scale and the overheat trips, this dosent seem to happen when c/heating is on, temp just drops to 70c . This is driving me mad, I feel a new boiler coming on, sorry for the length of this post but wanted to get all the facts in.
PS I put some sludge buster stuff in the circuit as well and the boiler seems noisier now.
