Europlex - engineer code reset
5 Feb 2016
I have been given an old Europlex Verifier 64 alarm panel and would like to install it at home. I've got the installation manual but the engineer code is obviously no longer the default xx10 code. Can I change reset this so I can reprogram the whole unit?
Thanks,
Matthew
Can't divulge on how to default/ reset a panel in a public forum security issue.
You will need the engineers manual to reprogram the unit, Consult the manual, if the panel is locked (not sure if this panel can be locked), then you wouldn't be able to default it at all.
