I've got what will hopefully be a simple question and would like some advice please.
I have an electrice coolbox which I can use in the car with the 12v lead it came with. It also came with an ac/dc converter which has a socket for the 12v car lead and a europlug on the other end. I would like to use this with standard UK sockets
I've had a read through these 2 old threads :-
//www.diynot.com/forums/viewtopic.php?t=81534&start=60
//www.diynot.com/forums/viewtopic.php?t=176362&start=30
I understand my primary 2 options for using the converter are (1) rewire with a UK plug and (2) use a converter plug. Although I will occasionally use the coolbox in Europe, I am more than happy to just fit a UK plug and use normal UK to Euro travel adapters when occasionally abroad as I feel "safer" with UK plug than using too many adapters etc
However, in each of the 2 options above, what I would like is some advice (back up) on is what amp I should be using/looking for (in the UK plug or the converter plug).
The ac/dc converter itself has input 220-240VAC 50/60HZ 1A and Output DC12V 5.8A. The europlug on it says 2.5A 250V~ which I understand is standard. The cable says 2x0.75mm2 which from one of the linked threads I take to mean should have a 6 amp maximum fuse. I understood the coolbox draws between 3.5A and 5.5A.
So when rewiring to a UK plug or using a converter plug, am I ok to be looking at 3amp as that is more than the europlug is currently - or does the 5.8A output of the ac/dc converter in any way come into it (and therefore I would need a bigger fuse in the UK plug/converter).
Also I presume that I should expect just 2 wires in the cable if I chop it and I would wire these up to a UK plug as normal neutral/live and there will be no earth?
Thanks in advance for any help
