I have a Eurosec CP8L control panel in my house which was working fine. Now I am having problems in that it still works fine, I can set it and it detects an intrusion but the external sounder (external siren) is silent. The only sound comes from the keypad (RPK). The speaker inside the alarm is also silent. The external sounder works if it is directly wired to the battery although slightly sluggishly. I tested the voltage across Bell+ and bell hold- and I got 13v. When I triggered the alarm the voltage between Bell+ and bell- was lower than 1v. Similar readings obtained across the strobe+ and strobe-. Can anyone please help as I am at a loss. Recently there was a power failure in our area so I am not sure if it is due to a power surge???. Thanks for your help.
