I have a Eurosec CP8L which I inherited with my house.
All is working fine however I want to change some settings and don't have the engineer code; and I can't make contact with the original installer.
I've downloaded the installation instructions and understand the unit can be reset to factory defaults. I thought it was a bit optimistic simply disconnecting mains power and expecting to be able to reset the unit, but I'm assuming when the instructions say remove all power from the system it means just that.
The question I have is, can I simply disconnect the panel from inside the actual alarm? I'm assuming in doing this I'm likely to set off the external and internal sounders? Is there any way to avoid that or if not, how do I turn them off again having disconnected the control panel? If I can, I'd rather avoid having the alarm going off while I'm reprogramming the entire system from scratch
