eurosec/risco cpx
1 Jan 2010
Nottingham
I have recently installed this control panel but not sure if the wiring for PIR is correct, there are 8 zones on the panel and one tamper. I have got 6 PIR's only and I have connected one pair from 6 pir to 6 zones on the panel and connected the tamper from 6 pir in series to the tamper connection on the panel. my question is should I leave the 2 unused zones as there are(there are no cables there) or short them? I am assuming I am using a global tamper but is there a way I can connect the tamper in a way where I can find out which PIR is giving tamper fault but at the same time leaving the alarm zone connections as they are?
has anyone got a engineer manual for CPX?
thanks
assuming the IS the same as the 490X
closed circuit wiring - 8 zone comman tamper
EOL wiring - 9 zone with individual tamper
follow the diagram in the manual
thanks for the quick reply.I have used the 2 wire option and shorted the unused zones and it seems to be working. I am now programing the panel but not sure which zone type to select for loung and other areas as there seems to be quite a few to choose from (alert, 24, monitor, ext/en etc) I tried monitor and everynow it will trigger so I think the zone type is wrong, can someone please help me with what they mean (I know what 24 hrs is for sure)
thanks
All zones should be 12hr meaning active when set apart from any dectector violated upon entry which should be set as Entry for first dection point ie door contact and then Access for a PIR in the Hallway(if fitted)
Hi, did you ever get your hands on a Engineers Manual for the CPX? I am struggling with an install and I have a list of questions I need answering. Cheers. Marco
