I have read previous posts under similar headings which refer to 'mythical EV sockets' but no-one seems to have seen them. So here goes on my particular issue:
I have just bought a plug in hybrid car (PHEV) which has a 15.6kWh battery as well as a petrol engine, with an electric range of about 40 miles. I expect to cover not more than 6,000 miles total a year of which (given the limited electric range) probably 3,000 miles at most might be electric. Fitting a full wall box charger (at a cost of £1,000 to £1,200) really doesn't seem worth it, when I will probably be charging 80-90% of 15.6kWh perhaps twice a week.
My house was built 1997 with pretty conventional electrics. A second CU has been 'Henleyed in' to serve a new kitchen which has left spare ways in the non-RCD side of the original CU (which is half RCD/half non RCD). The only connection left on the non RCD side is the burglar alarm. I was proposing to run in a new cable from an existing B32 MCB (could be changed to B20?) on the non RCD side of the CU to one of the mythical EV sockets fitted externally, specifically this one:
I recognise that a wall box charger would give me much faster charging but that's not an issue with a PHEV. I will have this car for at least 4 years after which I suspect I will go full electric when a wall box will become a necessity. So why not install it now? I am concerned that technology will have changed such that I will then need a new type of wall box/plug/cable.
So can I do this? Grateful for comments on practicality, legality and safety.
Masterplug EVH132S1SPA-MP EV Mode 2 Wall Charger With A Type DP RCBO
