- Joined
- 3 May 2019
- Messages
- 2
- Reaction score
- 0
- Country
Hi Guys,
I have experienced this a few times now. I turn off the mains, do the relevant cuts, allow water to drain, but there are still very small amounts of water coming out of the pipe. This makes soldering the pipe impossible, so I end up having to use a compression fitting instead, which works, but is sub-optimal.
Does anyone have any tricks to stop the flow completely so I can get a decent joint on the pipe ?
I just came across the Jet Swet tool, but that looks like it might be difficult to get into tight spaces and it does not appear to do bends/corner joints. I read about someone using some bread but not sure if that'll actually work ? anyone tried it ?
Do share any other tricks/techniques you have!
