You can use any make/brand of saw blade that has nearly same outer diameter, and exactly the same middle hole 'bore' diameter as required for your saw.
BUT I think that the issue for you is that Evolution saws have a special 'bore' size to stop you buying other brands. Most are 30mm, evolution is 25.4mm.
So then you have to go to elsewhere to get more choice then the one available at SF. : https://www.google.com/search?client=firefox-b-d&q=25.4mm+saw+blade
