Can anyone offer some sound advice on insulating a 70's timber framed house? Bought this house a year ago and in need of some repairs. Having new windows installed in a month or so.
Construction is timber framed with 70mm studs, spaces filled with mineral wool insulation. Plasterboard and skimmed on the inside, render over board over membrane directly fixed to outside of studs. Upstairs front of house has very 70's vertical tiles over board instead of render. There is no air gap between board/render and frame. No damp problems as far as I can see and house is not particularly cold although heats and cools quickly in winter.
Render is in need of repair in some places and window surveyor removed a few areas around windows - this has allowed me a good look at what's underneath.
So we are thinking of losing the 70's tiles and replacing with render and might as well re-render whole of house to refresh the look. I'm thinking there's a good likelihood that the board behind the render will also need replacing so is this a a good time to replace with insulation board e.g. 50mm EWI and render over that instead?
There seems to be conflicting advice over whether you can apply this over timber frame due to air gap but I'm 99% certain there is no air gap in this house. Is this then worthwhile or would the added insulation not make much difference?
Thanks to anyone who can help!
