I'm a first time buyer. I need your advice. I'm in the process of buying a house and survey and serches are completed. Just now my solicitor told me:
From Solicitor:
I would like to point out at this time that the seller does not have planning permission or building regulation approval for the annex in the garden, new windows, new boiler or electrical work commissioned and I have a suspicion they will not have planning permission or building regulation for the side and rear extension and internal alterations as revealed by the survey report.
In light of this, the seller has agreed to provide indemnity insurance for lack of planning permission and building regulation approval. Indemnity Insurance only gives protection against enforcement action by the Council, but not against structural failures or other inadequacies of construction.
It is important therefore that you decide whether as far as you are concerned there is a concern about the quality of the work. You must satisfy yourself with regards to the workmanship of this alteration.
The property has solid masonry internal walls. These have a mixture of finishes.
Survey report:
The walls are in good structural order with no evidence of any significant disrepair.Internal walls on the ground floor have been removed but we cannot confirm if loads have been properly redistributed. Although there are no obvious signs of failure this work may well have needed Building Regulation approval. We therefore refer you to our advice in Section I in this respect. In the absence of any consents or proper supervision, there is a risk that further support may be needed incurring additional expense and disturbance.
I'm not sure what I'm supposed to do here. House is not cheap and expensive what're the points I need to consider? should I go ahead or not?
Thanks in advance,
From Solicitor:
Survey report:
Thanks in advance,
