Hi guys
I just need to reassure myself that it is not our responsibility to relocate existing an cooker control unit to the prescribed safe distance when altering the position of the cooker connection unit? Obviously the customer should be made aware that it's not in the current prescribed area (and encouraged to pay to alter this) and a note should be entered on the minor works certificate. Currently it's above the double range cooker but the customer is installing a single cooker and the cooker control unit will then be just to the side, so it will be safer than the current situation.
On the same note the current cable to the cooker connection unit is run in mini trunking that drops directly behind the hob and oven from the above cooker control unit. This IS bad practice I'm assuming, although I can't find anything in the regs to suggest it's not allowed? If there is something in the regs that I'm not seeing could you please point it out to me because the customer wants the trunking run to the corner above the cooker and the dropped behind the cooker (just for aesthetics)
Many thanks,
Chris.
Many thanks,
Chris.
