expanded foam on upvc window frames
4 Aug 2007
Anyone know of a successful way to remove cured expanded foam from window frame ?
Thanks in advance
Let it go hard, you can then abrade it off. If it is on the outside, the sun will make it go weak brittle and brown over time.
buy a tin of "Foam Eater" available from shops that sell foam, but first, test it in the PVC to see if it causes staining or damage
