One room in my house is, was add on to the house, it is on sender blocks and I what to get more sport for the room. I a was wondering if I can use expanding foam to make a true floor for the room, like concert, and if not then how?
i do like the idea of using expanding foam - i'm just not sure that it would give the required amount of support. the foam tends not to recover well when pressed in too firmly.
i would go for some form of rubber or anti vibration strip sat between the joists and the floor boarding. i know this kind of thing is used to reduce the sound transfer on wood floors.
i'm not sure where you would get it from - i would tend to go to my local builders merchants shop.
you'll get us in trouble Deluks. hope the capital of culture is doing ok - not been in 08 yet.
i worked with Americans for a while and i think that helps a little - not to upset them or Raynamdu but they are all very much more direct than the UK.
