Will bog standard (diy) expanding PU foam cause a bridge for water if I put it in a cavity? I have looked online and it appears to be an open cell structure which is porous. Has anyone had any experience with this? I wanted to use it as a cavity closer around my door and on the cavity between blue bricks and flooring concrete - where I have removed bricks from under a window to fit the door...
