I've asked a similar question in the flooring section but no reply to-date, so please forgive me for trying here but I shortly need to order materials.
I have a wooden outbuilding with tanelised 22mm T&G wooden floor, fixed to tanelised bearers over concrete. It will contain audio recording equipment so the floor must be really solid to minimise noise and potential for creaking.
I'm minded to lay 1800 x 600 x 18mm spruce ply boards over the T&G for the flooring, sandwiching a 5mm moisture/thermal barrier material between.
So, with the T&G timbers exposed to the outside air, and the ply board above the insulating membrane, should I worry about dissimilar expansion/contraction and leave the ply to 'float' above the existing T&G floor (least-preferred option), or can I lock the ply sheets down with copious screws for improved solidity and reduced potential for conducted noise through the floor?
Thanks in advance.
FJ
Thanks in advance.
FJ
