Need some education on my CH/HW system. it's an open vented pumped system with a new potterton 40 boiler.
should the mains feed to the expansion&feed tank be left ON for normal operation? the ballvalve operates correctly.
I get the feeling that it should be, but surely this might introduce fresh, airy water into the system - obviously undesirable(??)
I had scottish gas in 10 months (immediately after moving in) ago to check over my system, and a few days after that, the system started banging violently about 5 mins after fire-up. I traced this to an empty feed tank (cold supply had been shut off). I turned the supply back on, and the tank filled & levelled out. No problems for the ensuing 10 months. (incidentally I am certain SG inadvertently turned the coldfeed off for some reason and forgot to switch it back on)
I have been thinking about it over that period, and decided to experiment last month so I went to the loft, and shut off the cold feed to the tank, and noted the level.
after 7 days of twice daily fire-up, I checked the tank again and found that the level in the tank had dropped considerably. However, the system was still functioning (though the boiler was a little more gurgly, quite noticably at initial fire-up) satisfactorily.
the system ran another week, and this morning I was woken up by the boiler banging away again and sucking air down from the tank.
The question is: where is the water going? surely this cannot be plain evaporation? I am worried there is a leak in the circuit, but I am in a top-floor flat, and I've been round the lower flats and there's no sign of water! (the system has been operating 10 months and no direct evidence of a leak!)
In the meantime, I have shut off the boiler, and I'm going to re-fill the expansion tank and add inhibitor. And possibly run a "control" experiment with a bucket of water to check what the actual evaporation rate is.
as an aside, during the 10 months when the system was OK (with coldfeed ON) I regularly checked the radiators for air and they never needed bleeding.
All comments on my waffling would be gratefully received!
thanks
Tris
thanks
Tris
