Our Potterton Prima F has been acting up for the past few weeks, rattling a bit and ocassionally cutting out (the electrics seem to work - boiler fan, pump stay on but the flame remains out and won't relight unless I power it off and on again). We've had an engineer out to look at the boiler and he can't see any issue with it, it was serviced a few months ago as well so I think the problem might lie elsewhere.
From reading posts on this site (very useful) I suspected the pump or air / sludge in the system. I've tried bleeding the radiators but now a few upstairs refuse to bleed. I think the expansion tank in the loft may have a blocked pipe to the radiators - the water in it contains lots of lumps of brown particles. I bled about half a pint of water from one of the downstairs radiators but didn't see any movement in the expansion tank. Cold water will fill in though if I shove the ball cock down.
Now the odd thing is the water I drained from the radiator is practically as clear as crystal. So to fix this, would it be over the top to get a powerflush of the system done, or would there be an easier way to clear the blockage out?
