Expansion Tank Feed
6 Feb 2020
Hi seen to be having problems with the Expansion tank...i heard the tank filling overnight when the heating was off I checked this morning and thought the part 2 ball valve was faulty so changed that over however ..
The expansion tank is not overflowing. The water level in the ET is constant as it seems to be filling and exiting at the same rate. I cant see any leaks anywhere.
Has anybody any ideas why the water is constantly trickling in even on the lowest setting ...like ive mentioned its not forcing the Overflow to empty but I'm wondering why the water isnt cutting out.
Cheers
Neil
Yeah thought that may be the case cant see where any obvious leaks are defo not upstairs gonna have to check my building and contents insurance see if imncovered ...anybody recommend a company local to Doncaster?
Have you got an external drain cock for draining central heating ?
Are your floors downstairs solid concrete or is there a void below wooden floorboards ,where heating Pipework is running ?
Hi Terry the central heating was drained down before via a ground floor radiator (attached to pipework hose attached then drained down) The floors downstairs are comcrete I did notice the one wall in the dining room near the floor smelt a bit damp
