14) CHANGING A CISTERN FLOAT VALVE
For the smaller F & E cistern supplying the heating system..........
Adjust float to cut off water when the water level is 100 mm deep to allow for water expansion.
How important is the depth. The level in my expansion tank is 175mm ensuring that the bottom of the overflow pipe is always under water. Could this explain why I continually have to bleed the system ?
