I've read some old threads about this and I think I know the answer already, now. Here is the situation:
The CH expansion tank is continually overflowing (steady drip out of the plastic overflow pipe emerging from the house, plus can be seen happening in the tank itself.
I drained water out of it until it was well below the overflow level, and watched to make sure the ball valve was still off. I adjusted it "down" as well, to make sure.
After a couple of hours, the level had risen again and it was overflowing. When I repeated the experiment but with the feed closed to the HW and CH tanks, it didn't re-fill. When I then opened the feed to the CH tank, the HW tank refilled.
So, I gather that the coil is leaking in my cylinder? With a house extension on the horizon I'm reluctant to replace the cylinder now as it may turn out that I need a whole new boiler setup later in the year anyway (going from five radiators and two hot taps to nine radiators and three hot taps) and my ancient baxi bermuda may not be able to serve that much.
What do you say? Is there any way to stall the problem now, or would fiddling with levels to stop flow from HW to CH risk the opposite happening, with CH water flowing into the HW?
