expansion vessel (glowworm)
8 Apr 2006
Gwent
ive jus had to drain water out of expansion vessel but not air , do i have to release air to refill with water or do i just refill system
Its a good time to make sure that the air side is charged properly before filling up your system. Make sure exp vessel is pumped up to 1 bar(approx) and then refill your system in the normal way and bleed all air as you go.
What about replacing lost inhibitor?
replaced inhibitor and plate heat exchanger due to lack of inhibitor and gave everything a good clean thanks for info ;)
