I have a Baxi 105e installed in the bathroom the same room as 1 of our showers. When running the shower in this bathroom, the boiler works perfectly.
Our ensuite shower was working perfectly until last week, when the water pressure in this shower started to drop when showering. It’s ok at first but almost becomes a trickle the longer you are in the shower. Plus the water can go hot and cold.
The pilot light on the boiler goes on and off, hence the hot/cold water.
Normally I’d clean the heat exchanger but given one shower works and one doesn’t. Could it be the expansion vessel needs replacing or re-pressurising?
I’ve cleaned the heat exchanger a few times now. Do I need a new one or is cleaning it just as good?
Thanks for you help
Thanks for you help
