expansion vessel pressure problem
27 May 2008
Roxburghshire
Howdy all, and thanks to everybody for previous advice.
Problem has occurred with pressure dropping in a sealed CH system after draining down/refilling to move a rad and add pipework for extra rad. If no leaks are apparent in new joints/pipework, is this problem likely to be the expansion vessel? If so what do i need to do to sort problem? I believe they can be recharged.... how do I do this? Should I try this?
Thanks again for all help
Search FAQ's on how to check and re-charge exp vessel. It's all in there ;)
