Hello
Our boiler (Baxi 100 Bahama) has been playing up lately (hot water not kicking in, heating not working). We discovered the system pressure had dropped to 0 a while back so we repressurised it to 1.5, pressed reset and got our heating back... temporarily. We have had to repressure the system at least once a day for the last 2 months. I assumed it was a leak but could find no evidence of this, and a friend suggested a fault on the pressure release system might be to blame. I found a pipe that goes out the back of the boiler to the outside of the house, and it does drip, so assume the pressure is escaping there.
Having searched the forums here I saw a thread about a similar problem which gave details on how to check if the expansion vessel is faulty. I think I have found mine (took cover off boiler, flatish red metal chamber located above control panel). I pushed the pin in the schraeder valve and water comes out... I take it this means the vessel is knackered?
Though I'm not a heating engineer I'm happy to replace this myself if it will solve our problems and there are no gas connections involved. What's the procedure and would I need any specialised tools? I have seen replacement vessels online for around £50 ex vat, is there anywhere cheaper online or around Bristol?
Many thanks in advance
Rory
Rory
