- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
I've just bought the DeWalt DCD776C2-GB combi drill from Screwfix. It's my first cordless drill!
I just do the odd DIY job but now that I've moved into a new house that needs a bit of work I will be doing a lot more.
I want to use it to drive screws amongst the usual. Until now I've always used screwdrivers but fancied the idea of simply using one of these instead.
The trouble is I can't successfully use the drill for this purpose and don't know if it's because of poor screws, technique or settings etc.
I could be expecting too much or I'm just useless!
For example, I try to drive in 40mm screws through loft chipboard and into the joists but only half way through the clutch (if that's what's happening) just slips and have to finish the rest by hand. I've tried all the torque settings and normal drill setting. I take it I'm not supposed to exert a lot of pressure.
After looking at a load of YouTube videos I just can't understand why it looks so easy for others!
I would say that the screws aren't the best quality but don't if it would make all the difference with top notch ones.
Thanks and hope you can help.
