I have previously posted about splitting the ring in my flat to install additional new sockets whilst insulating the walls in my flat.
The thought has just occured to me that there there is one wall in the lounge, that if I insulate, I will need to extend the exsting wiring by say 100mm to bring it though the 60mm of insualtion to remount the sockets. Likewise in the bedrooms, there are fused outlets for the electrical heaters that will need extending by the same. The new sockets will be mounted inline with the exsting, so the actual cable run through insulation should be less than 50mm depending on the depth of back box used.
From previous posts, I understnd that crimping provides maintenance free connections. is it acceptable to extend the cabling to the two affected sockets that way or should I be looking at re-wiring the circuits to extend? The exsting ring cabling is 2.5mm single core PVC insulated in conduit on a 32A breaker and the electrical heater circuits are on 1.5mm radials from the CU on a 16A breaker.
There is the added complication, that if I understand how the cabling was originally installed in the flat, the ring included a bathroom razor power point that was sealed up behind tiling when I had the bathroom replaced (Part P electrician used here, and fully tested afterwards complete with certificate, so I'm assuming maintenance free connectors were used). If I did re-wire, the leg into & out of that hidden junction can't be replaced.
Matt
Matt
