I have got a set of downlights for under kitchen units. There are 5 x 12v halogen lights from 1 transformer (from B&Q). The lights all have connectors and plug in to a connector block on the transformer. The cable on each light is 2.4m but this is not enough for one of the lights so my questions are
1. As I can't get an extension cable, can I just cut this cable and extend it using blocks (or would solder joints be better)?
2. What is the best cable to use? The existing cable is 0.75mm silicone cable. Would it have to be the same or can I use 1mm T&E?
Thanks.
Tim.
Thanks.
Tim.
