Hi all,
Knowing the general consensus regarding terminal blocks/connector strips on here I'll choose my words carefully.
I want to extend a 3 core 2.5mm2 by about two feet. I have 3A connector blocks at hand. Yes, there is the wago and ideal range of connectors to consider but this is DIY and I'm not going to that expense.
It just so happen that the connection itself will be accessible via an access panel. This is the only reason I'm considering extending a cable in this circumstance.
My question is : when making the connection what is the stronger/better way to use the terminal block/connector ? Two of the same core terminating in the same side or one on each side ?
Does the terminal block/connector have to be wrapped in insulation tape or can this be avoided ?
Many thanks for any information.
