This weekend we've had to install a new gas hob as a leak was found on the old one by a gas safe engineer who'd come to disconnect and old gas fire in another room.
The new hob is in and the gas safe man will be coming this week to connect it to the gas supply, however the problem I have is that the mains cable for the igniter is too short to reach the 240v socket that the previous hob plugged in to.
The plug in question is on the same plate as the cooker switch which you can see in the attached photo.
Is it ok to plug an extension lead in to this socket and then plug the 3 pin plug for the gas hob in to this?
Or is that not ok and if not, what will I need to do?
Jon.
Jon.
