I have a switched fused spur above the kitchen work surfaces and the fused spur feeds a socket behind the washer, this fused spur and socket are now redundant as the washer is plugged in elsewere. I wanted to add an outdoor socket but wiring directly the new outdoor cable into the fused spur would mean tearing into tiles and worktop splash back which I'm desperately trying to avoid.
Would I be able to use something like a 30a junction box to connect the fused spur cable that originally fed the washer socket with the new outdoor cable leading to the outdoor socket. (it would be tucked safely away behind the units).
The new outdoor socket "might" be housing a cheaper hot tub hence the reason I prefer the new ouutdoor double socket to be hard wired into the fused spur rather than plugging the new outdoor socket in to the old washer socket using a 13a plug.
Also, the outdoor socket is from Screwfix £9.99 (no RCD) so I am wondering, shall I change the fused switched spur for an RCD fused spur ?. It would be easier to see if there's any hot tub problem via indoors than the other side of the garden. Any help would be appreciated
