As part of a bathroom refit I’m doing myself, I need to move hot/cold water pipes from coming out of the floor behind the sink pedestal, to being coming out of the wall about 18 inches up due to us installing a floating vanity unit so the pipes aren’t visible below.
Pipes are 10mm plastic microbore and the wall
is plastered breeze block once I remove existing tiles. I’m comfortable chiselling the wall out at a good depth for the pipes, but I don’t think I have enough slack on existing pipes so need to extend slightly. What fittings should I use under the floor - I assumed 10mm compression? And also do I need to add any capping protection to the pipes in the wall before making good?
