Good Evening All
I am currently designing the roof structure of an extension I'm starting. The extension will be a timber frame (140mmx38mm panels stick built). The roof structure will be an oak rafter/purlin construction that will be left exposed under a warm roof.
Two bedrooms side by side with a 140mm dividing wall. Each of the purlins will sit on an external timber wall and this central dividing wall. As the external wall will only be carrying one purlin at that location achieving the minimum 80mm bearing will be possible. However at the locations purlins sit on the central wall, it will have to to take the purlin from each room (end on end) and therefore only be able to achieve 70mm bearing.
I would ideally like to achieve 100mm bearing for each purlin. Does anyone know a standard bearing extender that can sit on this central wall and extend the bearing available from a 140mm timber wall to minimum of 200mm?
Would prefer not to offset purlins as the roof slope is quite small so would look lopsided in the rooms.
Thanks in advance.
Dave
Thanks in advance.
Dave
