What is the correct way to extend a cable inside a consumer unit? Will crimps do the job?
Can cables be crimped before they enter the consumer unit so you have nice fresh cable in side the board, The cables would sit behind the mounting board?
Are you sure they don't actually mean PVC? 'Vinyl' is an imprecise term, but most commonly used to refer to PVC; other polymerised vinyl compounds (e.g.polyvinyl fluoride, PVF, and polyvinyl acetate, PVAc) are much less common.These are vinyl insulated may be different with PVC.
