Following an earlier post on the same subject I am hoping someone will be able to advise on the following: -
The existing concrete base is topped with patio slabs some of which are loose. When getting the concrete pumped in for the extended base the aim is to cover the sabs with approx. 50mm of concrete. Should all the slabs be removed first?
For the new part of the base I have dug out approx. 8m x 1.5m to a depth of 300mm. I am now putting in some hardcore from an old path. This will be compacted down with a whacker plate. I then intend getting a groundwork company to oversee the levelling etc.
The garden building will then have a timber base structure fixed to the base after DPM has been layed.
Is there anything I missed? Grateful for members views
