I have recently had an existing base for a conservatory entended by more than double in size and had a all glass conservatory put up.
I am in the process of putting wooden flooring down but before I do I wanted to know what the best way would be to join the existing base to the extended part? Currently the builder has just concreted up to the existing base leaving a very small gap between the two bases.
Should I make this gap a little bit bigger to maybe 10mm so that I can put an expansion joint in or is that not recommended? Bearing in mind the conservatory is up and I need to deal with the floor situation somehow!!
I would really appreciate some advice here!
Many thanks
Wayne
Many thanks
Wayne
