Hello, I'd be grateful for any advise.
I want to add two or three wall lights and a shaver socket in a sort of dressing room area. There's a pre-existing unused 'spur' from the ceiling rose loop going to a 20amp JB. Can I use this to suppy ALL the extra fittings [via additional 20amp JB's].
I wondered if the same principle applies here as with the 13amp circuit - that the spur can only supply one additonal fitting and can not be extened on?
If the above is not acceptable - is it acceptable to extend the existing lighting circuit which currently serves six roses [small flat] to incorporate the new fittings?
I could just about access the circuit immediately above the ceiling rose. There's no access from above and I want to do minimal damage to the ceiling.
Would choc blocks be an acceptable means to connect to the existing cable?
Any comment gratefully received.
