Extending the ring? Cabel too short!!!!
21 Jan 2007
Bedfordshire
I need to add another socket in my kitchen. I cannot spur off from an adjacent socket, as i need to add a spur off the new socket (fused outlet for fridge). Unfortunately, the existing cable doesnt reach the position of the new socket and there is no way i can replace the cable without destroying the place!!
Can I (at ceiling height) cut the ring and replace with a longer cable down to the location of the new socket?? using a 25mm back box/30A choc block and blanking plate?? The re-make the ring by connecting the new socket to the old?
What are the rules relatign to cable runs?? I ah installing vertical runs directly to the sockets and short horizontal runs to the spurs.
The work is to be certified for Part P, so what are my options?
Thanks,
Matt.
If you can physicsally do it( have enough length spare) then what you propose is ok.Is it not possible to get into the ceiling void above?Would make a neater job.
