First of all, I have performed continuty tests to confirm that the sockets are on a ring and not radial. From a socket I want to run horizontally two 2.5mm t&e cables to extend the ring. Is it Ok to use choc blocks inside the back box to join one of these cables to one of the supply cables
NOW:
supply - socket - supply
HOPEFULLY:
supply - choc block - new stuff(socket - socket - socket - dp fcu) - socket - supply
the new stuff would be a few sockets and a double pole FCU
since the cables so far are in safe zones, what means of protection do they need, as far as I understand capping will be fine - am I right?
Here is where I'm a little unsure. I want to mount a plasma on the wall, buut this idea may have to be scrapped for a stand if I have to.
There is only 3cm between the painted surface and the breeze block behind. i don't want to actually put in the hdmi cables and whatever else I may need because I haven't got all my gear. I also want to avoid taking the connectors off the end of cables like scart so they can be pulled through. I am a bit lost at what to do here. also would it be OK to run firetuf(no interference) cable from the fcu to an aerial socket with the socket taken out termintad in a chocblock, connect the erth of this choc block to the backbox and then cut off the plug from the tv cable and connect it there
Finally the floor isn't in so could I run the speaker cables in this
and also an aerial cable from the socket at the other end of the room
thanks for reading
look forward to your replies
NOW:
HOPEFULLY:
thanks for reading
