extending to the boundary
18 Feb 2006
Birmingham
Earlier this year I purchased an extended 5-bed semi hich has a single storey rear extension.
On the side which met the attached neighbours the extension is set back about 1 meter, and I wanted to extend this up to the boundary so the room can actually be used, as currently just over 5ft wide, which is a wasted space
Yes.
Planning:
Both Permitted Development (subject to complying with specific dimensions) and non Permitted Development can be built (subject to planning permission for the latter).
Building Regulations:
If within 1 metre of the boundary then it must be built substantially of non combustible material (check exact wording) - See Building Regulations Part B - Fire Spread section.
Hope that helps.
Yes.
Planning:
Hope that helps.
Hi
That helps alot.
Currently has windows to side and all brick built. Will just be moving the wall over, and removing windows.
When you say "set back" you mean "set in" (as in the left wall of your house is 1 metre to the right of your left boundary) ? Set back more implies that the frontmost wall of the extension is 1 metre further away from the road than the frontmost wall of the original house..
Ensure you don't have things like gutters overhanging your neighbour's property. If the wall has a gutter, boiler flue, roof edge or other projecting feature then it is the feature that is the thing that is built right up to the boundary, not the wall. Hanging things over the boundary and into your neighbour's space will likely cause problems somewhere along the line
Your right, I meant "set in".
I guess I would need the wall on my side as the roof will need to overhang on the verge. I'm planning to put a mono pitch roof, if there's enough height under window.
