Hi, hoping someone could give me some advice on what work is likely to be needed in this situation :
I live in a new build and my water main comes in under ground via a blue MDPE pipe from the front of the property, goes under the property, to the back wall of the property (under sink). We are now looking to have a house extension which means this wall will be pushed back around 2.5 metres. This means of course that the water mains pipe will need extending. My question is: what option(s) are there? Could it simply be extended using a compression fitting and if so could this be buried within concrete floor?
Just want an idea of what work is likely so I can budget for it.
Many thanks in advance
