I have had a builder in to help with the blockwork for an extension I am building, but it hasn't gone to plan. The outer leaf has been built to a height of about 2m, and I have since added the 90mm PIR insulation, ready for him to build up the inner leaf.
The cavity at DPC level is only 90mm in places instead of the intended 100mm, so there is no residual cavity for the insulation. The outer leaf actually bows in slightly too, so if you run a spirit level down from the point where the wall protrudes most, it means that the first block would overhang the existing blocks (below DPC) by about 20mm.
The builder was due to continue with the inner leaf today but turned up this morning only to collect his tools and leave without saying anything. He has left me to deal with the problem, so I am just going to finish the rest myself.
My question is, how should I deal with the slight bow in the outer leaf? I could offset the first block by 20mm and perhaps fill the void underneath with concrete, or I could build it following the curve of the insulation and correct it with plasterboard (though would this make the wall potentially liable to buckle?) Alternatively I could trim the back of the insulation down so that it sits flat and level, though I may have to try and reattach the foil, and maybe not tell building control.
Any advice would be much appreciated!
