I have a friend who lives in a row of detached houses that are separated by a drive way to each property.
Next door to my friend’s house the neighbour built a garage to the bottom of the drive and runs parallel to the side of the bottom of my garden.
My friend’s suffix and guttering hangs over the neighbour driveway along with a rain water pipe that runs into concrete on the neighbour’s drive into a communal drain at the bottom of the neighbour’s drive.
The problem is the neighbour has announced they intend to build and extend the house on the driver way and run a flat roof under my friend’s suffix and guttering and build on top of the garage in the back garden which will take away views from my friend’s rear bedroom and reduce the value of the property.
If my friend requires access to repair guttering or brickwork to the gable end wall to the side of the driveway access will be blocked due to the new build which will be under my friend’s suffix and guttering by building a flat roof.
The neighbour says they can always climb onto the flat roof to carry out repairs to guttering if needed. Also, the water drain would need to be dug up and replaced as well as my friends water drain pipe.
My friend objects to this new build but was informed they can do nothing to prevent it?
Surely the neighbours cannot simply build what they want and reduce the value of my friend’s house, spoil views to the rear, force them to re-route Sky Tv cables, alter drainage and re-route a water drain pipe from their property without permission?
I think I have read someplace that if an extension is to be built they need to leave at leave half a meter between properties to enable the neighbour complete repairs to guttering and brickwork etc?
Advice would really be appreciated to resolve a stressful situation, many thanks in advance.
What can my friend do to prevent this build?
