I have decided to build my single storey extension (24 sqm) myself but obvioulsy using trades where i need them like brick layers, plumbers, electricians.
I have had the drawings done and planning agreed by the council. They has specified 600mm wide by 1metre deep. The extension will be built with block and then rendered to match rest of house.
I will get a man with a digger to dig the foundation trench and then will get a concrete company to deliver the concrete. I have been advised the following and i just want to confirm:
1. The trench will be 1m deep from lowest lying point so could be more than a metre in some places?
2. I will need a polystyrene sheet in the foundation trench to barrier where it joins the house for expansion purposes.
3. The concrete should be poured to a level equivilent to 2 engineering blocks plus mortar joints below DPC so that the DPC can be laid at same height as exisitng house and then celcon block on top
Is all this correct? Also what do i use in the founcation trench to go over the soil and drainage pipes? so once the foundation has been poured the can be accessed?
Thanks in Advance
Ian
Thanks in Advance
Ian
