D
Deleted member 231862
I am looking to change the cylinder locks on my French doors.
The door on the right is easy to do, with removing the screw from inside. However on the left door, this is not accessible as easily.
View media item 103599
From what I can see, this plastic extension is held on by 6 screws which I assume I need to remove.
View media item 103597However, most of the screws I can only see 1/2 of it because of a metal plate which I assume needs removing first, but there are so many screws on there, I am just not sure which screws need to be taken out.
View media item 103598
Any advice would be great.
Also if this is easy to do with a normal screw driver or if the plastic is hard it would need to be a battery powered?
Thanks!
Thanks!
