I've read lots here and found it a very helpful site and learnt more than I ever thought I'd want to know about roof design and construction but I've got to the point where I need some help. I'm building an L shaped extension across the rear of my East Midlands house; part is a lean to roof, the other, deeper end is gable ended with a valley where the two join. It will be all be warm roof, insulation above and between, with the ceiling plasterboard nailed under the rafters, so no ties.
The building control officer won't specify the timber sizes but seems to be easy going and would be happy to accept generous sizes with C24 timber. My builder would also be delighted to over specify the timber. This would be a simple solution but I really want to minimise the rafter depth as I want 200mm over the rafters (75mm of insulation plus counterbattens, tiling battens and interlocking double roman concrete tiles). If the rafters get too deep then I have to compromise on the thickness of insulation, which I really don't want to do, or risk the pitch dropping below 22.5, requiring even deeper rafters.
Also, I don't want the facias to be any deeper than necessary for appearances sake.
The lean to roof is 1705/1805mm horizontally from the abutment wall to the inside/outside of the wall plate, with a total rise (from the top of the wall plate) up the abutment wall of 1160mm to the top of the roof covering. I have a spreadsheet to calculate the pitch, which with 100mm deep rafters birdmouthed by 1/3 to the wall plate and 1/2 to a 50mm deep pitch plate is 25.6 degrees.
I would like the rafters spacing to be 600mm for better thermal performance.
Unfortunately I don't have a copy of Eurocode 5 span tables (4th edition currently in force?) but I did find this:
http://www.buildingcontrol-ni.com/assets/pdf/TechnicalBookletD2012.pdf
which has comprehensive tables which I'm guessing come from the 2nd or 3rd edition of the TRADA document?
Marley tiles have a load of .47kN/m^2 so I assume the dead load with insulation and battens will be less than .5kN/m^2 and I assume an imposed load of .75kN/m^2 applies (only 25m above sea level and very rarely see snow).
I calculated the clear span to be 1954mm, so from Table 4B.19 (page 41 of the 2012 NI document I linked above) shows a C16 38x100 to have a span limit of 2.01m but a 47x100 has a more comfortable margin at 2.23m as does a C24 38 x 100 @ 2.17m
So:
1) Where exactly is the clearspan measured? Is it along the bottom of the rafter between the points where it just meets the wall and pitch plates? Or is it along the rafter between the deepest part of the birdsmouths?
2) Could I get away with 38 x 100 C24 @ 600mm spacing (better than 47 x 100 thermally)? I understand that the later editions of the span tables reduced the maximum spans, especially for smaller timbers?
3) The gable roof has a ridge beam span of 3382mm (abutment wall to inside of inner leaf of gable), with rafter spans approx 1600mm either side, pitched a bit less then 30 degrees. The BCO says he would be happy to see 9" x 3" C24 for the beam but looking at the tables this might be marginal. Do I look at Table 4B.22 (page 42, purlins span, c24 for pitch 22.5 to 30) looking for purlin spacing >= 1600mm?
4) How would I select the valley beam dimensions, which would have a span of around 2550mm? Is this one of those cases with no standard solutions (theoretically) requiring formal calculations? Would I just use the same size as the ridge beam and assume that would be more than adequate without calculating loads?
5) Should I be able to find a copy of the current span tables at a local library easily enough or should I go to the local council and the BI dept and ask if I could have a look at their copy?
I've found plenty of local council build reg advice documents which publish limted tables, but they all seem to have different values - I'm not sure if that's because they are based on different editions of the Eurocode span tables or because they have decided to locally tighten the standards for roofs built without formal structural calculations?
Sorry for so many questions but I'd appreciate any help/insight you can provide,
Tony
So:
Tony
