Exterior Coatings an alternative to exterior cement/paint
18 Sep 2004
I'm considering rendering the back exterior of my house and having it painted in a sandstone colour.
There are bare facing bricks showing must be over a 100 years of grime with black motar, Both neigbouring houses have tidy bare cemented walls.
I was thinking in terms of avoiding having to paint again after 4 years on a traditional cement render. By using resin or liquid plastic based render/coating.
These new coatings are available by these National companies they simply spray on these coats in the colours of your choice.
They claim they give 15 years protection at the costing in the region of
£2000 for a full house.
WEATHER- PROOF EXTERIOR COATING are they all what they are cracked up to be.
Is there an alternative DIY product that will render the walls without the need to paint at the same time?
This sound too good to be true. What apeals to me is that you only have to render once and you dont need to paint.
bump? is that the name of the product.. you not giving much away are you.
No, moderator has kindly push your topic back to the top of the list (known as bump)as you has no response from us to wake us up :LOL:
dphomes said:
WEATHER PROOF EXTERIOR COATING are they all what they are cracked up to be.
Well they say guaranteed for 15 years, so what happen after that ? I'm not keen on weatherproofing outside rendering because the mortar need to breathe therefore trapping moisture inside. I know they say breathing through the paint but can't see how.
I have a Red Canterbury peddledash with lime over 20 years ago and still looks good but not all pebbledash are suitable for property for appearance reason and have heard they de-valued property.
If I was in your position I would have rendered with a colourtone cement which give a colour without having to paint it.
See this
