Exterior door seal loose
12 Sep 2010
Lancashire
Another post, about another exterior door!
The weather/draught strip for our front door has deteriorated/come loose.
There appears to be a 1-2mm notch in the door that it was previously in, though trying to 'shove' it back in with a flathead screwdriver doesn't seem to work.
Does it need glue/adhesive to make stick, or should I jut replace it with a new strip.
If replace, is it just called and 'external draught strip' or something else?
I assume its a PVC door?
Can you post a pic? Most likely a bubble or flipper gasket that can be purchased on ebay
